It is currently Sun Aug 09, 2020 10:34 pm
 Disk3 Target 5 - 3155/7222 - Critique Please
Post Disk3 Target 5 - 3155/7222 - Critique Please
Sat Mar 28, 2015 1:08 pm
Post Re: Disk3 Target 5 - 3155/7222 - Critique Please
Much, much better! BUT still some things to fix:
1. First, Stop writing "end" on your S3 freehand sketch on page 2 ( if that's what it says). You only write "end" when you are completely done with the session on the last page. which in your case, should have been on the Site Template.
If you need to take a break you are permitted to do so at the end of a stage 4 matrix table just write: Break - Date and time. . If you have to take a break before you finish an S4, then you have to redo the prompt over again. So if you break at S3[A], when you come back, you have to start over with S1[A].
To resume the session, go on a new page, write the page number in top right corner and write:
Resume 1234 / 5678 ( or whatever the TRNs are)
Date
Time
then you will begin with a S1 prompt for the next aspect: From the top of [A] SSBP ( or whatever comes next) and go on as normal.
2. I think you may have been using your S2 dimensions for your page 2 sketch. HUGE MISTAKE and will RUIN your entire session.. You only use S2 dimensions to help with Analytical sketches, like S3[X], not freehand
S3 freehand sketches are made kinestheticly with the hand... you are to feel around, and let your hand make archetypes where you feel they should be on the page. This process should take around 15 secs( not including the labeling of the aspects, which you will allow your hand feel around for the most important aspect and label it with [X] and so on.
See Ed Dames' post here on how to properly do a freehand sketch: viewtopic.php?f=3&t=2615&p=16256&hilit=above+paper#p16256
'Draw' first in the air, above the paper. Ask yourself if that movement is purely an ANS-kinesthetic response, or if you are controlling your hand to any degree. If no conscious control, transfer the movement to the paper, in the form of a line or lines. Pull your hand back up, and repeat the process until you are satisfied that there are no more key site aspects/archetypes present.
3. Even in S4, when you write your AI's you need to put AI-Anxious and drop pen, just like at the end of S2.
When you do a new session, make these corrections and we will go from there. I don't want to overload you with corrections, so just make these changes for right now.
Sat Mar 28, 2015 4:07 pm
I don't want you to use up all of those DVD targets and subsequent discussions with this fundamental freehand error persisting. Here are the TRNs for your next target. Be sure to keep employing the changes I mentioned in other thread and this one ( post your session right here in this thread, don't make a new:
[ 1598 / 5982 ]
Sat Mar 28, 2015 4:57 pm
[ Time : 0.104s | 16 Queries | GZIP : On ]
