It is currently Mon Sep 28, 2020 9:14 am
 after disc 3 / question
Post after disc 3 / question
nitty gritty question for post-disc 3 practice. i have the cue from the disc but need to assign a TRN which i can get from the learnrv site.
1-what do i do with the TRN? write the the TRN and cue on white blank 3x5 index card?
2-since i will be running the same cue many times as instructed, do i need a new TRN each time?
thank you.
-Chris
Sat Apr 16, 2011 12:49 pm
Post Re: after disc 3 / question
See this response in another thread. Does this answer your question?
Subject: NYT front page photo
RVRobot wrote:
You must use fresh TRNs whenever you construct a new cue. Once you've done that you can re-use your TRNs day after day as they will always point to that same cue. Here is the correct procedure:
1. Get a fresh piece of paper, cue card, whatever
2. Write the following:
[ / ] Today / New York Times / front page / primary photo / target reference
3. Once you are sure that the cue is correct, go to the TRN generator (http://www.learnrv.com/templates.cfm) and generate fresh TRNs.
4. Fill in the blank [ / ] with the TRNs you just generated. This locks those TRNs onto the cue next to it forever.
5. Start your session with the TRNs you generated.
6. Repeat for practice. Mix this with other practice targets to give yourself some variety.
Be sure to post your sessions so we can correct any structural errors.
The TRNs point to the cue, which instructs your unconscious where to direct its attention. This may be discussed later in the DVD series than where you're at now. If you've completed the DVDs it would be worthwhile to review them.
Sat Apr 16, 2011 7:57 pm
yes it does thank you. when i write it for USA Today or NYT, i will post here to be 100%.
Sat Apr 16, 2011 10:28 pm
[ Time : 0.150s | 13 Queries | GZIP : On ]
