It is currently Sat Feb 22, 2020 12:13 pm
 DVD # 2 - Target 3 - Warning Target Discussed
Post DVD # 2 - Target 3 - Warning Target Discussed
DVD # 2 - Target 3
I am very frustrated, as I am missing the X as the target. The target is very clearly drawn on my paper and described clearly but it is B!!!
I drew flying cylinder, flat pizza like, cold, metallic, gray, shining, reflective, in my (I) was gravity, pushing - had direction of movement and drawing perfect. The problem is that was B!!!
My X target was very clearly a very large man made structure, building, with voices, very expensive construction, like possibly billion, I did pick up hysteria, excitement at the X site, which as odd. My A was a monolithic structure that was transmitting, but clearly man made. Both X & A were man made, I did not get an affirmative on the flying cylinder as man made. When I get better at this I plan on looking at this closer.
Now my question is, I think that the reason this might be happening to me is that my mind is thinking of X, A & B as targets. Since there was only one object in the picture, I looked around to find two more. Is that correct? I need to figure out how to stop this so that I hit the target you are looking for with my X. Can you give me an idea what my mind should be trained on with this A & B. I obviously am missing it.
Any feedback would be greatly appreciated. Frustrated, but excited.
Tue Dec 28, 2004 12:45 am
Simple answer: you have no business thinking at all, in S3 or any other stage (with the exception, to some degree, of the S3 analytical sketch and the site template). It is your mind-body, not your thinking brain, that produced the freehand sketch -- it is the same mechanism that gravitates towards the most important key site aspect. Get out of its way!
Another point: If the target and the site are synonymous, then (after practice) you will only produce a single key aspect, to wit, [X].
There are even cases, albeit uncommon, where multiple targets appear (eg., several murderers), or even multiple [A]'s (eg., planets orbiting a star, where the star is the target -- in the case of let's say a binary star system with three orbiting planets, we would have two [X]'s and three [A]'s each numbered with subscripts). Regardless, it is your body that does the labeling, not you brain. Stop thinking and start RVing.
Tue Dec 28, 2004 2:42 am
[ Time : 0.097s | 13 Queries | GZIP : On ]
