It is currently Sun Apr 22, 2018 4:17 pm
 Falcon 9 Launch / Root Cause Analysis
Post Falcon 9 Launch / Root Cause Analysis
Cue help please ?
Falcon 9 Rocket / Launch Explosion / Root Cause
I could use a photo but I want to practice correct RV syntax.
Assume this cue fails if there are multiple launch explosions in the future ?
How to lock on to only the current event ?
Fri Sep 09, 2016 1:35 pm
Post Re: Falcon 9 Launch / Root Cause Analysis
Xor,
I would like to see the cue flow a little better for you.
" Most recent Falcon 9 rocket launch explosion / root cause "
Instead of using the words / root cause
You can attempt / causal agent
Dan
Fri Sep 09, 2016 5:47 pm
Thanks Dan,
The reason I originally chose 'root' cause is because I wanted to filter out and go beyond answers such as 'the explosion was caused by oxygen + fuel + spark' or similar and go deeper.
So might I ask, what is it about 'causal agent' that bypasses such results ? Is the cue intent enough to over-ride viewing 'a spark' - it is still a causal agent, is it not ? Is there something particular about this phrase that works well ? No doubt it was chosen from past experience but I am curious why.
Mon Sep 19, 2016 12:27 pm
Dear Xor,
Think of this in the terms of a ' res ipsa loquitur ' situation-scenario.
Yes, the cuing term ' causal agent ' has been employed many times successfully to get to the bottom of an issue or question.
The cuing term ' root cause ' may get you where you want to go indeed !
You just have to do the remote viewing session work to find out.
Good question's.
Sincerely,
Dan
Mon Sep 19, 2016 10:33 pm
Xor wrote:
Cue help please ?
http://www.bing.com/images/search?q=Falcon+9+Rocket&qs=n&form=QBILPG&pq=falcon+9+rocket&sc=8-15&sp=-1&sk=
http://www.bing.com/images/search?q=falcon+9+rocket+explodes&qs=AS&sk=IM1NM1AS5&FORM=QBIRMH&pq=falcon%209%20rocket%20&sc=8-16&sp=8&qs=AS&sk=IM1NM1AS5
Seek the truth.
Mon Dec 26, 2016 5:25 am
[ Time : 0.115s | 11 Queries | GZIP : On ]
