It is currently Mon Jan 27, 2020 5:00 pm
Post new topic Reply to topic  [ 20 posts ]
 let me ask you something
Post Re: let me ask you something
Raptor wrote:
RVRobot, why is anyone here so elitist regarding HARV?
Sell a DVD but don't tell anyone how it is correctly executed. :?:
Raptor, there is absolutely nothing wrong with the material or cues in the financial markets DVDs. The matrix is VERY clear that if an HARV cue does not work you will get a clearly wrong answer the first time. If there is one thing your unconscious hates more than running the same type of targets over and over, it is the thought of running a bad cue over and over. It won't just work and then stop working. If it works the first few times, the cue is verified. The experience of the OP is symptomatic of something else.
Alex wrote:
Next week's work of 40 sessions may get us closer to a declaration of success.
The biggest mistake people make in utilizing the FM and Sports betting DVDs is shifting from remote viewing all kinds of targets, to shifting to exclusively HARV sessions. You just can't get away with that. Alex and a few other former pro-team members have certainly fallen down that blackhole.
The subject of novelty has been covered ad nauseam on these forums, but it isn't just HARV sessions, it occurs in ALL projects.
The Major has pointed that out even on Stefan's project here (http://www.rvcommunity.net/viewtopic.php?f=27&t=7217&start=44) and just about every other long-running project on the forums that continued focus on a single project will result in degradation. It isn't a question of HARV versus full sessions. Drudgery impacts all sessions.
It is clear that one can only focus on a single project for so long before the unconscious wants to gouge out your "RV eyes" with a sharp object in an attempt to make you consider trying other things. People are thick headed and prefer to do what they want to do over and over again.
You can probably bet, the OP ran most of these sessions without breaking off to run any meaningful amount of unrelated non-FM projects.
It isn't even enough to just run an equal amount of non-HARV sessions.
To be clear, not even that will save you in the long run, you must take extended breaks from a particular FM and Sports betting fetish and run completely different projects during that downtime.
No one does this. They seem to think if they all remote viewing activities for a month, they can pick the FM viewing up next month without issues. That is just not so.
You can bet if you haven't found your sanctuary, that novelty will wear off even faster than normal as the matrix can hijack your sessions to point you in the direction of doing what your unconscious knows you should be doing over what your conscious mind chooses to do.
The other problem is personal limitations that must be resolved on a case-by-base basis as it is specific to the viewer involved.
Tue Jan 17, 2012 12:15 pm
Your breakdown on utilizing HARV is much appreciated kocmodpom.
Tue Jan 17, 2012 4:16 pm
[ Time : 0.084s | 13 Queries | GZIP : On ]
